Hi, I want to create the shortest distance among points. Hence I have to build surfaces from the connectors
  • July 17, 2017
  • 39 views
erik_jan
Forum|alt.badge.img+26
  • July 17, 2017
Can you explain a little more?
The shortest distance between two points is a line. The VertexCreator can do that.
Building a Surface from points can be done using the SurfaceModeler transformer..
