Hi I have the intersection points in point feature. I want to have attribute field as the street address as 2 St/3 Ave. The street network has line features. is it possible to get this happened to point feature at intersection? thanks in advance.
  • Mar 12, 2023 5:23 PM UTC
  • 7 replies
  • 66 views
  • Mar 21, 2023 10:12 PM UTC
Hello I tried, I only get the name of one street. I couldn't get the Ave.
@kris_ab​ check the feature in the feature information window. You should see a list called _candidate{}. But, perhaps try your points as the Base and the Lines as the Candidates
  • Mar 22, 2023 8:47 PM UTC
Awesome! thank you. I have found them in attribute under feature information. I am trying to extract three attributes _candidate{1} ,_candidate{2} and _candidate{3} into the shapefile attribute table. I hope there is a way to do so.
  • Mar 22, 2023 8:48 PM UTC
  • Mar 22, 2023 9:32 PM UTC
@Mark Stoakes​ I got it. I used attribute creator to create those four attributes. thank you very for your help.
