We want to automatically write 3D data to an existing 3DScene in ArcGIS Online. The data consists of borehole samples (geometry simple 3D-cylinder). We have tried using the Esri Indexed 3D Scene Layer-writer but the output does not show correctly and we can't create pop-ups showing the attribute data (although it looks like it's there). We're not sure why this doesn't work but figured we'd try here first to see if we can get any pointers to a best practice.
So, can anyone please help shed some light on the best way of doing this - updating 3D-data to an existing 3D-scene in ArcGIS Online? (We will want to be able to do this also with mesh-data... for instance a ground model.)
If we look at some random other SLPK from another Arcgis PRO project we see statistics:
I see no options for adding the statistics with FME. Perhaps somebody knows how to add these. Could be in Arcgis PRO. No problem.
