Hi Everyone, I have a problem. I want to merge our line database with OSM. Is there any options to, make a if condition. What I need: If geometry is same, and the street name. Thanks.
  • Jun 20, 2022 7:56 AM UTC
  • 67 views
dallas2011
evieatsafe
Forum|alt.badge.img+28
  • Jun 22, 2022 6:33 PM UTC
Hi @dallas2011​ thanks for your question.
I believe the answer to your issue is the ChangeDectector transformer! It can check to see the difference between geometry as well as attributes such as "street name". You can see in the image below that you can select the checkboxes "Check Attributes" and "Check Geometry". If you are interested in fuzzy matches then we suggest changing the Vector Tolerance to something you are comfortable with.
changeDetectorFor more information on the ChangeDetector check out this article on Change Detection!
Hope this helps,
Evie
