Hi, Can anyone help me with process to extract schema from a GDB format
  • Feb 24, 2023 11:04 AM UTC
  • 398 views
pbonagiri
  • Feb 24, 2023 1:05 PM UTC
If you read the File Geodatabase using a FeatureReader, you'll have the option of either reading the data, the schema, or both, see here under the heading "Schema/Data Features":
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/featurereader.htm
@pbonagiri​ If you use the most recent version of FME 2022 then the domains will also be include in the schema list attributes created by the <schema> port that @david_r​ mentions above.
If you want the detailed schema then you can use the approach suggested here using an Esri XML Workspace document. At the very bottom is a link to an answer by @ebygomm​ with the arcpy you can use in PythonCaller to export the XML Workspace Document.
