Hi All, I have a complex polygon with smaller polyons within a bigger polygon, multiparts and lots of overlap issues. I want to be able to desegregate, remove multiparts and be able to select each polygons individually. Any thoughts will be helpfu
  • Oct 11, 2021 12:40 PM UTC
  • 60 views
Hi All, I have a complex polygon with smaller polyons within a bigger polygon, multiparts and lots of overlap issues. I want to be able to desegregate, remove multiparts and be able to select each polygons individually. Any thoughts will be helpful.
danilo_fme
Forum|alt.badge.img+58
  • Oct 11, 2021 12:53 PM UTC
Hi @mat_1​
You can use the transformer Deaggregator for desagregate features. You can select polygons by attributes using the transformer Tester.
Thanks in Advance,
Danilo
  • Oct 11, 2021 12:58 PM UTC
Hi @mat_1​
Thanks in Advance,
Danilo
Hi Danilo,
I have used Disaggregator to do the splits and areagapandoverlaycleaner to remove overlaps, not fully doing all polygons only some of the polygons did disaggregate.
