Help with InlineQuerier
  • Feb 10, 2019 10:27 PM UTC
  • 9 replies
  • 219 views
mmccart
Forum|alt.badge.img+33
I need help joining a table based on whether or not a feature falls within a date-time range.
Table A: Has an attribute with unique recorded date-times for all 3,233 records
Table B: Has a "Start Date-Time" and an "End Date-Time" field for all 29 records
I built this query:
and it was able to join and return 2,731 records that met the criteria.
Here's a sample of what was joined:
My issue now is how to join return the other 502 records that may not fall the range listed above. I've tried several iterations such as NOT BETWEEN, IS NO, <>, etc.
Any advice would be appreciated! Thanks.
Note: Tables are generated from a CSV so that's why I chose InlineQuerier.
FME 2018.1.1.2 (Build 18586) 64-bit
  • Feb 10, 2019 10:39 PM UTC
Isn’t it a different type of join you’re looking for? Possibly a right join maybe.
https://stackoverflow.com/questions/38549/what-is-the-difference-between-inner-join-and-outer-join
  • Feb 11, 2019 4:57 AM UTC
Agree. This type of join might be what you need.
Forum|alt.badge.img+54
  • Feb 11, 2019 8:58 AM UTC
Are you looking for all records returned, including unmerged in one query, or a separate query to return only unmerged?
Something like this for all records
SELECT * from mergedRecords M
left join
aRecords A
on M.fullDateG between A.startFullDateA and A.endFullDateA
or this if you just want to return unmerged
SELECT * from mergedRecords M, aRecords A
on M.fullDateG not between A.startFullDateA and A.endFullDateA
mmccart
  • Feb 11, 2019 1:23 PM UTC
Unfortunately, I get the following error that states RIGHT and FULL OUTER JOIN are not currently supported. I would love to use a a RIGHT JOIN here.
mmccart
  • Feb 11, 2019 1:33 PM UTC
left join
aRecords A
@egomm the top script returns 3,236 records which is 3 more than 3,233 I originally started with. I ran a duplicate filter and inspected the 3 records and it is data I need to keep. I'll take this flow for now and swap out those 3 records some how. But it would be nice to avoid all of the extra transformers. Note: I tried SELECT DISTINCT and just SELECT and both statements returned the 3 extra records.
  • Feb 11, 2019 10:22 PM UTC
That’s interesting as only ever used inner joins.
  • Feb 12, 2019 2:09 AM UTC
"left join" is applicable.
  • Feb 12, 2019 10:35 AM UTC
Do you have overlapping periods in the table you are matching to? This would result in additional values as all matches in the left table are returned.
mmccart
  • Feb 12, 2019 10:56 PM UTC
Ended up leveraged the 'Adjacent Feature Attributes' function to back-fill missing data fields.
