Help : Converting 2D objects to 3D in Revit ?
  • Jan 7, 2021 7:00 AM UTC
  • 142 views
Hey, we are working on ceiling grids in Revit and heard about FME can convert 2D grid objects to 3D and furthermore creat ceiling plates. Is there anyone who have worked on this before? I'm new to FME 😝
Going from 2D to 3D is as simple as dragging in a 2DForcer and assigning a base Z value. From there, you put the features through an extruder with a height to build your solids. I haven't personally created what you're looking for but it shouldn't be that difficult.
FME is one of those software where if you can think about it, you can do it. It's that powerful.
Workbench example
3dwb
Input features 2D
3d2
Features in 3D and extruded
3d1
Manipulated data with a buffer
3d3
