Helmert-translation
  • August 28, 2014
  • 6 replies
  • 97 views
sigtill
Forum|alt.badge.img+25
Hi
Is there an easy way to add a custom transformation with Helmert-parameters to features in FME? Ie A0,A1,B0,B1 - parameters? I have looked through MyCoordSysDefs.fme and articles describing this however it would be nice if there was a Transformer that you could use for this.
  • October 24, 2014
Hi
I also need this.
If no transformer how to work around?
Thank you!
jelle
Forum|alt.badge.img+22
  • October 31, 2016
Hi @sigtill,
I was looking for Helmert transformation as well today. Have you found a workaround for this?
jelle
  • October 31, 2016
Hi Sig,
sigtill
  • November 1, 2016
Hi @sigtill,
Hi! I accidentally sawe this, was hoping that I would get a notification by email when my username was mentioned. The Affiner and 3D-affiner seems to be what you need @jelle
sigtill
  • February 17, 2021
Any news on this?
chrisatsafe
  • February 17, 2021
Any news on this?
Looks like the 3DAffiner is still the best bet, unless you'd wanted to test out some python like this: https://docs.scipy.org/doc/scipy/reference/generated/scipy.linalg.helmert.html
Could make for a good hub transformer.
