Hello , i would like to use a date (20221117) as an attribute , how can i do ?
  • Nov 17, 2022 11:55 AM UTC
  • 5 replies
  • 66 views
Today i use the datetimestamper to have my date in a string, but i want to convert to an attribute
Thanks in advance and sorry for my bad english ! 🙂
Best answer by geomancer
You can do this in an AttributeManager.
The attribute will not be exposed. To expose the attribute, you will have to enter it's actual name in an AttributeExposer.
Date_as_Attribute_Name
Forum|alt.badge.img+63
The output of the DateTimeStamper is already an attribute. You do need to make sure you have that attribute defined on your output feature type though.
  • Nov 17, 2022 12:52 PM UTC
Thanks for your quick answer, indeed it's an attribute , called "_timestamp" , i need to replace "_timestamp" with the date of today
geomancer
Forum|alt.badge.img+71
  • Nov 17, 2022 2:18 PM UTC
  • Nov 21, 2022 9:48 AM UTC
Thanks for your answer geomancer
After using your tips , i obtain this screenshot, is it normal ? imageimage
geomancer
  • Nov 21, 2022 9:58 AM UTC
In the AttributeExposer, you have to enter 20221121 (or any other attribute name you want to expose). Entering @Value(_timestamp) will not work.
