Hello. I have some 2d points in a GML file and want to create some vertical cylinders in their positions.
  • July 6, 2023
  • 17 replies
  • 138 views
n.d
Forum|alt.badge.img+7
I thought I should have two lists, one with the current Xs and Ys and another with the same Xs and Ys and some defined heights as their Zs. And then make some lines between these two lists and after that make the cylinders.
Can anybody help me to implement it?
virtualcitymatt
Forum|alt.badge.img+47
The workflow your probably looking for is as follows.
Bufferer (pick radius) >3DForcer (set base z height e.g., 0m for ground) > Extruder (define the height of the cylander).
The GML reader should bring in your points correctly but you might need to play around with the settings if not.
n.d
  • July 7, 2023
Thanks for your help. Should I change the coordinate system after reading the data?
virtualcitymatt
ah yeah sorry for not replying before. You will need to make sure that the units of your data are in meters (or feet) rather than LatLong. So you may need to reproject but it will depend on the data.
n.d
  • July 7, 2023
Thanks. And for having some spheres on the top of the cylinders, which approach do you recommend?
virtualcitymatt
The bufferer can also buffer points into Solids -Just change the buffer type to Solid. If you want the sphere to be on top of the cylinder than you will need to create a point in the place you want the center of the sphere. This could be done by using an Offsetter to move the original points in the positive Z direction by the height Value
n.d
  • July 7, 2023
Great. and for colorizing the surfaces, should I use SurfaceColorSetter?
n.d
  • July 10, 2023
Hello. I would be very grateful if you answer my question about colorizing.
  • July 10, 2023
Did the SurfaceColorSetter work?
n.d
  • July 10, 2023
The process of creating these spheres takes a very long time. Is it normal? I have 200,000 points and it is taking one second for each...
virtualcitymatt
The 3DBuffer can be pretty slow - yeah.
n.d
  • July 10, 2023
And there is no faster way?
virtualcitymatt
heh! there is often a faster way, however, it depends on how much time you have to experiment, test and play around. It will also likely end up a lot more complex and unstable.
n.d
  • July 10, 2023
Is there any Parallel Processing solution?
virtualcitymatt
https://community.safe.com/s/article/parallel-processing
n.d
  • July 10, 2023
That's a great way. Thanks. I want to export the geometries as an IFC file, but the written file is emty. Would you please help me to solve it?
virtualcitymatt
Check the FME log file for any warnings towards the and and try to address the issues. IFC I think can be pretty annoying to work with in FME (like CityGML) but I'm not really familiar with it as much as other formats
n.d
  • July 11, 2023
Hi, Let's think out of the box. I just want to use these geometries in the BIM processes. Could you recommend the optimal file format for the exporting procedure? (Considering that the imported file format is GML)
