Having issues with using a GeoJSON file with the SpatialFilter and Cutter transformers
  • Apr 29, 2019 4:52 PM UTC
  • 90 views
Hi Everyone,
I having some issues using a GeoJSON file in a spatial filter or clipper. When I inspect the layer, as well as the other layer I'm comparing it to, they clearly overlap and I have made sure that the coordinate systems are set correctly. Is there a reason why GeoJSON would not work for these spatial transformers? I have used the transformers before multiple times but have never worked with the GeoJSON format.
I have attached a file which includes a simple workspace showing the issue as well as the 2 source file (which have been made as anonymous as possible).
There are 2 files included:
Area 1: A shape file which was created from an Esri Geodatabase
Area 2: A Shape file created from a GeoJSON file (the original file can be shared if necessary)
I would really appreciate any help with this.
Thanks in advance!
debbiatsafe
Forum|alt.badge.img+24
Hi @ponting7
The input file format should not have an effect when using spatial transformers (eg. Clipper, SpatialFilter) to analyze spatial relationships.
What does have an effect are the coordinate systems of the datasets. As mentioned in the documentation:
Area 1 and Area 2 are in different coordinate systems. The CoordinateSystemSetter simply tags input features with the specified coordinate system and does not reproject features.
Please use one of the reprojection transformers to reproject one set of data to the same coordinate system of the other set and you should the correct output from both transformers.
  • Apr 30, 2019 9:06 AM UTC
Hi @ponting7
Thanks for the advice, that has worked perfectly
