Hatches and line improperly in DWG
  • Dec 29, 2018 6:15 PM UTC
  • 8 replies
  • 190 views
maccabi
I'm having trouble building my DWG file again. I've done tests in several ways, using FeatureWriter, using template file, but nothing helped me.
Follows my workspace:
I just need to read the file and write it to DWG identical to the input file. See the differences in the images below:
the input file
the output file
input
output
input
output
Thank´s
Best answer by itay
Shalom Yehuda a @maccabi :)
I have run your template and there are several warnings in the log file when doing that.
From my experience working with a template on your writer is a very effective way to attach the desired styling to the output.
The only thing you have to make sure is that the incoming feature types names are existing in the template file. That way FME will match them during writing and use the styling from the template file.
See the following article for more info.
After inspecting your template and input data I noticed that most of the features dont have any values in the format attributes you are using in de DWGStylers.
Another issue to consider are the pattern types that dont match with the pattern names. So for example in the feature type RESERVA LEGAL you get a warning like:
AutoCAD Writer: The combination of pattern type 'Pre-defined' and pattern name 'GR_INVSPH' was found to be invalid. Using a default predefined hatch pattern of value of 'SOLID'
telling you that FME is setting it to SOLID.
I am not a big AutoCAD expert but it seems like you are missing some pattern types that dont ship with FME.
Hope this helps,
Itay
danilo_fme
Forum|alt.badge.img+58
  • Dec 29, 2018 6:34 PM UTC
Hello @maccabi
Thanks your Workspace template.
I opened here in my machine in FME Desktop and the input file is:
My question: Are you using AutoCAD program to see the Input and Output files?
Obrigado / Thanks,
Danilo
maccabi
  • Dec 29, 2018 10:22 PM UTC
Hello @maccabi
Obrigado / Thanks,
Danilo
Hi @danilo_fme.
Thank´s for your attention.
Correct! I´m using AutoCAD 2019 version to see the Input and Output files.
danilo_fme
  • Dec 30, 2018 9:01 PM UTC
Hi @danilo_fme.
Hi @maccabi
Thanks.
Please, open the transformer DWGStyler_12 and change GOST-GLASS to GOST_GLASS - the correct type Fill Pattern Name:
I'm checking anothers errors.
Obrigado,
Danilo
maccabi
  • Dec 31, 2018 12:37 AM UTC
Hi @maccabi
Thanks.
Obrigado,
Danilo
Ok Danilo,
Thank´s for your tip. I will change.
I´m grateful for your help still this moment.
what you discover will be of great value...
danilo_fme
  • Dec 31, 2018 7:36 PM UTC
Ok Danilo,
Excellent.
In the same transformer please remove the attribute PatternScale
And in the Navigator choose the option for Writer - Attribute Output = Inserts
The result DWG in AutoCAD 2019:
Obrigado / Thanks,
Danilo
maccabi
  • Jan 1, 2019 1:15 PM UTC
Excellent.
Obrigado / Thanks,
Danilo
Very good Danilo.
I think that DWG files have many configurations in FME.
Now I´m broken my head with line type like FENCELINE in first photo, and SEDE without hatch.
Happy new year!!
Thank´s
itay
Forum|alt.badge.img+19
  • Jan 2, 2019 2:26 PM UTC
Hope this helps,
Itay
maccabi
  • Jan 3, 2019 2:55 PM UTC
Hope this helps,
Itay
Shalom @itay!!
Thank´s helped a lot. Mainly the article.
Some files have associative hatches. FME does not work correctly with associative hatches unfortunately.
Regards
