Has anyone resolved the workspace log Warning for coordinate system when working with Snowflake Spatial Reader?
  • Oct 26, 2023 11:01 PM UTC
  • 12 replies
  • 581 views
alanbc
Coordinate system of reader identified by keyword `SNOWFLAKE_SPATIAL_1' has changed from `LL-WGS84' to `'
If you set the coordinate system on the Snowflake Spatial reader to LL-WGS84 the warning changes to.
NOT changing coordinate system of reader identified by keyword `SNOWFLAKE_SPATIAL_1' from `LL-WGS84' to `' -- mapping file setting of `LL-WGS84' overrides coordinate system `' read from file.
If you set the coordinate system on the Snowflake Spatial reader to EPSG:4326 the warning changes to.
NOT changing coordinate system of reader identified by keyword `SNOWFLAKE_SPATIAL_1' from `EPSG:4326' to `LL-WGS84' -- mapping file setting of `EPSG:4326' overrides coordinate system `LL-WGS84' read from file.
Ultimately the Warning has no impact on the workbench or translation, the data is definitely LL-WGS84 and a CoordinateSystemExtractor will confirm this but best practice for me is to resolve as many log warnings as possible and this one would seem to be spurious or a bug?
Thanks
Alan
danminneyatsaf
Forum|alt.badge.img+13
Hey @alanbc​, thanks for bringing this issue to our attention. I don't think it's necessary that we log these messages, at least not as warnings in the translation log. They could be logged as normal messages instead. There's definitely some improvement we could bring to the wording to make it more clear what FME is doing. I've submitted an enhancement request with our developers to get this looked at. For your reference, the ticket number is FMEENGINE-80871.
We'll update you here if any changes are made to the Snowflake Spatial Reader coordinate system logging.
alanbc
  • Oct 30, 2023 10:46 PM UTC
Awesome, thanks @danminneyatsaf​ .
tb09114
Forum|alt.badge.img+28
  • May 30, 2024 6:36 AM UTC
Hi @danminneyatsaf I have the same issue within a FeatureReader, reading from a GeoPackage:
NOT changing coordinate system of reader identified by keyword `R_9' from `EPSG:25832' to `ETRS89.UTM-32N' -- mapping file setting of `EPSG:25832' overrides coordinate system `ETRS89.UTM-32N' read from file
But I understand that this is simply a warning with no implications on the performance or translation and is rather an information than a warning.
danminneyatsaf
@tb09114 that’s correct, these log messages are just warnings and won’t have any implications on the performance or translation of your workspace. For now you can ignore the messages. I just took a look at the ticket, FMEENGINE-80871, and the issue is set to be resolved in FME 2024.1.
fredrik.ekstrom
Do you know in what version of 2024.1 it will be resolved? I’m trying build 24612 and it still marks these messages as warnings.
danminneyatsaf
@fredrik.ekstrom The issue was resolved in FME 2024.1 (build 24556). If you’ve opened an existing workspace in build 24612, you can right-click on the Snowflake Reader in the navigator window and select Update - otherwise it may still show the coordinate system warnings in the log.
fredrik.ekstrom
So it’s only for the Snowflake reader? We get the same warnings from all readers more os less MSSQL/PostGIS. We get like this line
“NOT changing coordinate system of reader identified by keyword `MSSQL_SPATIAL_1' from `EPSG:3008' to `SWEREF-99-13-30' -- mapping file setting of `EPSG:3008' overrides coordinate system `SWEREF-99-13-30' read from file
Since EPSG:3008 is the same as SWEREF-99-13-30 this is not a problem and in my opinion not a warning, more like information.
I was happy to find this post with the same “problem” to be fixed but that was not the case since it is not covering all readers.
My bad.
danminneyatsaf
@fredrik.ekstrom are you able to share a sample workspace & sample dataset (this could be exported as an FFS file)? I haven’t been able to reproduce the issue yet but sometimes these warnings are dataset dependent. Once I’ve been able to reproduce the issue I’ll promptly file a bug report to get this issue resolved.
Cheers,
Dan.
miquelrs
Forum|alt.badge.img+10
  • Jul 23, 2024 1:51 PM UTC
I’m having a similar problem using a SQL Server reader, from tables that use British National Grid (EPSG:27700):
“NOT changing coordinate system of reader identified by keyword `MSSQL_SPATIAL_1' from `EPSG:27700' to `OSGB-GPS-2015-OSTN15' -- mapping file setting of `EPSG:27700' overrides coordinate system `OSGB-GPS-2015-OSTN15' read from file”
I never understood what it means, and I remember seeing this problem for quite a long time, talking about years.
Some log files show 20,000 warnings of this type, and some produce no warning at all.
Is this going to be fixed along with the Snowflake Reader issue?
oppetveiten
Forum|alt.badge.img+7
  • Nov 21, 2024 11:57 AM UTC
We have the same problem in FME Form 2024.1. What is special is the FME reads the wrong coordinate system and we can’t change it.. The geodatabase is in UTM-32N in ArcGIS Pro and QGIS. The dataset is produced in FME 2023 with a file geodatabase writer.
Error message:
Coordinate system of reader identified by keyword `FILEGDB_1' has changed from `ETRS89.UTM-33N' to `_ETRS89.UTM-33N_0'
matthieuv
Forum|alt.badge.img+30
  • Mar 21, 2025 6:53 PM UTC
I get the same warning when reading ffs files. FME 2024.2 build 24801.
matthieuv
  • Jun 25, 2025 10:03 PM UTC
And the same happens with build 24801 for Feature Classes from Esri Geodatabase (ArcSDE GeoDB) set to EPSG 4326.
