Grouping ObjectIDs by Attachment Count Closest to 1,000
  • May 26, 2025 10:28 AM UTC
  • 110 views
marta.podsiad
Forum|alt.badge.img+12
I have a CSV file containing ObjectID and associated AttachmentNumber values.
I want to group the ObjectIDs so that the total number of attachments in each group is as close to 1,000 as possible.
How can I achieve this?
crutledge
Forum|alt.badge.img+55
  • May 26, 2025 10:41 AM UTC
Hi ​@marta.podsiad I think you could use the StatisticsCalculator. GroupBy ObjectID and that should give you counts for attachments when selected in the Statistics to Summarize.
Hope that helps!
alexbiz
Forum|alt.badge.img+35
  • May 26, 2025 1:59 PM UTC
Assuming the following dataset :
One way to do that could be the following
AttachementSum conditional value :
GroupID conditional value :
This method will create groups based on the attachmentSum. Each time the attachmentSum exceeds 1000, the groupID is incremented and the attachmentSum is reset.
It’s a bit tricky, and workbench will give alerts about non-existing attributes, but it will work :
You can then use the groupID attribute to create lists of obectIDs, concatenate, etc…
Hope that helps !
  • May 27, 2025 10:39 AM UTC
Tips: In a similar case, I would expose the new attribute names with AttributeExposer beforehand, in order to avoid the alerts.
