Grouping lines - index row
I've got a knotty problem that I can't seem to think out.
I've got a CSV file that comes out of system A (the coloured section of the image).
It's invoices that need paying against Purchase Orders.
An invoice starts with a H (header) and has a number of D (detail) rows.
On occasion a PO Item may have it's TAX split and the source system outputs the tax splits.
The target system can only cope with a single line per PO Item number so I create a list and group on the appropriate columns and return a list on the ones I need to aggregate...
Tax code - first code
Amount - sum of the values
Quantity - sum of the values
So far so good.
BUT the DOC_ITEM (blue) must be sequential based on the number of rows in the actual invoice.
Screenshot 2021-10-06 171650It's late in the day so my brain may have stopped working but I can't think of a way to achieve the goal...
How can I relate a line item back to the number of line items in the invoice and set DOC_ITEM accordingly.
Any help gratefully received.
Thanks
Forum|alt.badge.img+50
Assuming all the data is always coming in properly ordered and that EML.... string is a unique identifier for each invoice you can use a Counter with that attribute as the Count Domain (if I recall correctly that parameter was called Counter Name in older versions). It'll reset every time a new value for that attribute comes by.
Screenshot 2021-10-07 at 08.54.04
  • October 7, 2021
New day and lots of reading up on transformers .....
It's easy with a bit of SQL knowledge (and remembering that InlineQuerier is a local sqllite database).
SQL gives the easy capability to include a row number
 ROW_NUMBER () OVER (
    PARTITION BY "ITEMDATA-PO_NUMBER"
    ORDER BY "INVOICE_DOC_ITEM"
  )-1 as newDOC_ITEM
  • October 8, 2021
Ahhh thanks @Hans van der Maarel​ ...
I'm running 2020.1 version of FME and that option doesn't exist.
Time to work on the upgrade process. having to uninstall FME Server just to install is a bit of a pain.
Thanks again
Thanks again
In 2020 the Counter does have that option, but it's called differently, "Counter Name" if i recall correctly, so no need to update FME Server just for that 😉
  • October 8, 2021
Thanks again
Head banging icon....
Less haste more speed...
Thanks so much.
FME is a product in 2 halves.
On the one hand really good and does a huge amount...
On the other really frustrating as so many transformers do such a similar thing and the terminology doesn't always jump out to me...
Why use a simple Counter when I can write a nice bit of SQL and use the Inline Querier
Thanks again.
Thanks again
Yeah, I totally understand it can be daunting sometimes. With 500-ish transformers it's not always easy to figure out which one you need to perform a certain task. Unfortunately, other than trying to break down your process into small chunks and building up experience I still haven't found the magic way to quickly get to the point where you immediately know which transformer you need. To be perfectly honest, I think I'm not saying anything too boastful if I say I'm a longtime (23 years, most of those as a Safe partner) poweruser and I probably have never used half of the transformers that are in FME right now. Nor do I know what they do.
Long story short: that's why the community is here, feel free to ask, we're happy to help. And don't be afraid to experiment 😉
  • October 8, 2021
Thanks again
Ohhh I've never been afraid to play 😎
Out of interest how would you say Power Automate / Azure Logic apps compare?
I've used FME for maybe 3 years but much longer using code; FME is good for non coders and it also self documents (to a point).
Thanks again
I don't have any experience with Power Automate or Azure Logic, so I really can't comment on that.
I do agree that FME is a great solution if you don't like coding. I've taught myself a number of programming languages to a somewhat competent degree over time but being visually oriented I can work a lot better and faster with FME.
  • October 8, 2021
Thanks again
