Grouping duplicated values and assigining certain value for duplicates
  • Jun 28, 2018 7:18 AM UTC
  • 8 replies
  • 211 views
Hey,
I am working on table which include duplicates for address field. Earlier I had to define one record from the duplicate set and assign there value "keep" and for the rest of duplicated records I had to assign value "dup". In the end of the day, duplicated records need to be found in the repository with attribute Merged_Id which indicate ID of the "keep" record from the duplicated set.
I would like to ask how to do it in the smartest way, considering conditions that if Merged_ID has missing value and address is duplicated in the certain group (left side of the pic), duplicated records 'dup' will have Merged_ID the same as "keep" record (right side of the pic).
Thank you!
pratap
Forum|alt.badge.img+12
  • Jun 28, 2018 7:53 AM UTC
Assuming that you want to fill only Merged_ID attribute and you will submit values in Merged_ID attribute as you have provided in sample excel
Kindly find the workbench attached
xlsxr2none.fmw
Pratap
Forum|alt.badge.img+63
Looks like @pratap and I were working on this at the same time. I like that solution (it does require the data to be sorted, but a Sorter will do that of course), but here's mine too anyway.
  • Jun 28, 2018 8:22 AM UTC
There is more than one way. The advantage of this workflow is that it won't block feature flow. I would adopt this VariableSetter/Retriever approach if the performance is critical.
  • Jun 28, 2018 8:32 AM UTC
Thank you for all answers and solutions, I will test them!
taojunabc
Participant
  • Participant
  • Jun 28, 2018 8:58 AM UTC
You can also use the following method.
pratap
  • Jun 28, 2018 9:01 AM UTC
This is the same which I suggested
taojunabc
Participant
  • Participant
  • Jun 28, 2018 9:05 AM UTC
I am very sorry, I only saw the answers of redgeographics and takashi.
pratap
  • Jun 29, 2018 5:36 AM UTC
No issues,I understand.
You have to add one more condition (before this condition) that if value exists retain the value...
