Group n points by proximity
  • May 7, 2019 3:17 PM UTC
  • 85 views
djmcdermott
Forum|alt.badge.img+7
Hi FME'ers,
I have a dataset containing points. I would like to group them so that there is n points per group by proximity. Imagine a voroni diagram but instead of 1 point, its n. For Example, I have 30 points I have want to group them into 3's. This would give me 10 groups with three points each and they would be the nearest points to each other.
Thanks,
David
davideagle
Forum|alt.badge.img+21
  • May 7, 2019 3:54 PM UTC
Hi @djmcdermott, I'd give the SpatialSorter a go. It's a custom transformer that utilises a Hilbert Curve methodolgy and should do what you want. Just play with the grid size parameter to get a finer result and in your case add the optional group size of 3... Hope that helps.
https://hub.safe.com/publishers/safe-lab/transformers/spatialsorter
