Group column A, merge column B
  • Nov 27, 2025 2:26 PM UTC
  • 135 views
scootercat_nl
A caseA column code contains both unique and identical values ​​(e.g., A, A, B, C, C, C, D, E, E).A second column names contains different names.I want to group a column, but the names associated with it need to be merged.How can I easily solve this in FME?
Thanks in advanced!
Best answer by alexbiz
The aggregator should do the trick.
You can group by any attribute, in your case “code”, and concatenate the attribute you want, “name”
alexbiz
Forum|alt.badge.img+35
  • Nov 27, 2025 2:52 PM UTC
Hey, do you have example datasets of what you have and what you want as a result ?
scootercat_nl
  • Nov 27, 2025 3:08 PM UTC
See my example Excel File.
In reality I obviously have different data, but the idea is the same.
alexbiz
  • Nov 27, 2025 3:17 PM UTC
scootercat_nl
  • Nov 27, 2025 3:25 PM UTC
It can be that simple, right?
Thank you very much for your response.
