Good morning, I was wondering if there was an equivalent of a radial raster convolver please ?
  • May 29, 2022 9:35 AM UTC
  • 8 replies
  • 140 views
moustik
I am working with rasters and want to fill some No Data Value cells with new data using a Raster Convolver (square matrix, with 0 in corners). To do an extent.
When I use this, it still creates cells with value 0.0 in the corners where I would still want no data in this corner ; so I could repeat the process if needed (and fill a new gap instead of using a 0 value that will have an effect of values for next iterations).
I am asking if there is a way to have this in FME, or to use any self-made matrices to be applied on rasters.
Thanks
SG
daveatsafe
Forum|alt.badge.img+24
  • Jun 3, 2022 8:36 PM UTC
Hi @moustik​,
According to the RasterConvolver docs, specifying a weight of 0 signifies the cell will not participate in the calculation. This makes it possible to specify custom shapes of the kernel.
In the Advanced Properties of the RasterConvolver, please try setting Center Pixel to Ignore Pixel Nodata and Neighbor Pixel Handling to Use Center Pixel.
moustik
  • Jun 16, 2022 2:52 PM UTC
Hi @daveatsafe​ ,
I have used both of those parameters already, which is why I am asking.
The aim of the matrices is to calculate cells to fill nodata value from initial map/figure that are 10 cell-radius away of the coast.
I will put different figures below to tell you what I am looking for:
Figure A is the starting point, giving figure B in Arc using a radial matrix with a radius of 10 cells
FME_Figure_A (which is the same as Figure_A), Figure C is supposed to give the same results as figure B (which is not), using 2 raster convolver with radial matrices (0 in corners) with a radius of 5 cells. The calculated values that are kept are the ones where there is nodata in Figure A (or FME_Figure_A).
Figure_AFigure A
FME_Figure_AFME_Figure AFigure_BFigure B
FME_Figure_CFigure C
Here is the transformers suite I used:
FME_transformers
moustik
  • Jun 21, 2022 10:58 AM UTC
Hi @moustik​,
Hello @daveatsafe​ ,
Have you seen my answer below ?
Thanks
daveatsafe
  • Jun 21, 2022 4:02 PM UTC
Hi @daveatsafe​ ,
Figure_AFigure A
FME_transformers
Hi @moustik​,
Would you mind sharing a copy of your workspace?
moustik
  • Jun 22, 2022 9:29 AM UTC
Hi @moustik​,
You'll find a copy attached here.
Thanks
daveatsafe
  • Jun 23, 2022 8:33 PM UTC
Hi @moustik​,
Hi @moustik​,
Thank you for the workspace, but it is a little too complex for diagnosing this issue. Would you mind simplifying to just a single RasterConvolver, and including a test dataset and the process you are trying to replicate in ArcGIS?
moustik
  • Jun 24, 2022 10:42 AM UTC
Hi @moustik​,
I want to replicate the ArcGIS output in FME.
The inputs are Ek_peak_risk1 and Ek_time_risk1 TIF files.
ArcGIS, using a FocalStat tool, extends the value of the raster cells where there is no value yet.
In Arc, the tool uses a circle of radius 10 cells where it applies a Majority operation. For this reason, I am using 2 raster Convolver with circle (putting weight 0 for the corner of the matrix) with a 5 cell radius (matrix 11 x 11).
I zipped the folder containing the different outputs (the ones from Arc and the ones from the FME tool)
Cheers
daveatsafe
  • Jun 28, 2022 7:31 PM UTC
Hi @moustik​,
Hi @moustik​,
Maybe try using a 21x21 convolution instead of the two 11x11 convolutions. You can do this by setting the Size to Derived from Weights, then providing the weights in an attribute.
I am attaching a modified workspace illustrating how to do this, and also create the weights list from a circle diameter.
