gnomonic custom projection
  • Sep 14, 2018 1:57 AM UTC
  • 59 views
nicholas
Forum|alt.badge.img+14
I have a raster representing rainfall intensity as detected by radar.
The image is in a custom gnomonic projection. I want to reproject into a Lat/Long GDA94 projection.
How do I define a new custom projection in FME?
The projection information I have been supplied with, in a .map file is;
IDR663.map
66 Brisbane (128 km)
projection = Gnomonic
center_longitude = 153.24001
center_latitude = -27.71810
lon0 = 151.93095
lat0 = -28.85765
lon1 = 151.95828
lat1 = -26.55640
lon2 = 154.53113
lat2 = -26.55632
lon3 = 154.55867
lat3 = -28.85755
Thanks!
chrisatsafe
Hi @nicholas,
You can create custom coordinate systems for use in FME, using this interactive form. You can start from an existing FME Coordinate system or Esri Projection WKT. If neither are selected, you will start with a clean slate. You will then need to add the custom coordinate system to FME by following the instructions in the About Adding Custom Coordinate Systems Documentation.
Alternatively, you can manually customize an existing coordinate system from an existing coordinate system by following the instructions listed on the About Custom Coordinate Systems Documentation.
I hope this helps.
- Chris
