Hi! I have a gml file that i have downloaded from the statistical bureau of sweden. This is the data source: https://share.scb.se/OV0105/Xml/PD/pd_befolkningsfordelning_totalbefolkning_nt.xml
It is in GML format and the data is structured in 10km squares. However, I can't seem to be able to convert it to any other format. The geometry im getting is just a bounding box for the entire dataset, not the specific 10km squares. I have found very limited resources to help with this problem online. The final destination should be in an enterprise geodatabase.
Has anyone else had trouble with this? Thankful for any help.
/Alex
There's probably a proper way to work with the data, but I guess this method also works 😏
