Global Temporary Table that Contains ST_GEOMETRY
Good evening.
I have created the below global temporary table on our development schema, and within the FME workbench, I am trying to create an ARCSde reader that will use this table.
CREATE GLOBAL TEMPORARY TABLE myglobal(
  IGEOM              ST_GEOMETRY,
  HU100                   NUMBER,
  POP100                  NUMBER,
  POPPEP                  NUMBER
) ON COMMIT PRESERVE ROWS;
When I attempt to create the reader, I receive the below error message:
An error occurred while attempting to open the table, feature class or relationship class 'myglobal'. The error number from ArcObjects is: '-2147155648'. The error message from ArcObjects is: {Abstract Data Types not supported [myglobal][STATE_ID = 24]}
I tried creating the table with the ST_GEOMETRY column and then creating a reader to access the table within the FME workbench and there were no issues.  Is there something special I need to do to work with ST_GEOMETRY?  I'm encountering a lot of issues using that type, whereas I encountered none when using SDO_GEOMETRY.
Thanks very much.
Joe
  • March 5, 2013
Correting a type:
I tried creating the table without the ST_GEOMETRY column and then creating a reader to access the table within the FME workbench and there were no issues.
  • March 5, 2013
(I can't type too well this afternoon :))
Correcting a typo:
Hi Joe,
A couple of questions: Both of the above needs to be in place before the ArcObjects-based reader will be able to access the data.
Hope this helps.
David
  • March 6, 2013
Ah, thanks David--I knew there was something basic I was missing!  I'm brand new to ST_GEOMETRY and so didn't know the table had to be registered.  Unfortunately our office is closed today because of snow, but tomorrow I will try this and see if I can view the table using ArcCatalog.
Thank you!
Joe
