Getting Schema Reader to see SQL SERVER Database connection?
jakeweaver
Participant
Hi folks, I'm trying to get the SCHEMA reader to read a MS Sql Server non spatial database. I keep trying to give it the correct Database Connection - but at the moment it wont. see it. Is there a way to make the Schema reader correctly get the database connection properties?
  • May 11, 2021
You can use a FeatureReader and tell it to only read the schema, e.g.
featurereader schema
jakeweaver
Participant
  • Participant
  • May 11, 2021
Thanks! - I hadnt realised the difference between the Schema Reader and a FeatureReader. Useful - very appreciated.
