Get the attributes names with python
  • Dec 14, 2015 12:25 PM UTC
  • 9 replies
  • 846 views
danilo_fme
Forum|alt.badge.img+58
Hello All,
I would like to use python to get the attribute name from a feature. The API Documentation i found the Class FME Feature - getAllAttributesNames().
I my pythoncaller is:
import fme
import fmeobjects
def processFeature(feature):
atributo = getAllAttributesNames()
pass
But doenst work.
  • Dec 14, 2015 12:34 PM UTC
The getAllAttributeNames method returns a list containing all attribute names which the feature has. For example, this script creates a concatenated attribute names and assign it to a new attribute. Try this and check the result to know the functionality of the method.
    attrNames = ','.join(feature.getAllAttributeNames())
    feature.setAttribute('attrNames', attrNames)
Takashi
danilo_fme
  • Dec 14, 2015 1:11 PM UTC
Takashi
@takashi Thanks your help.
I used in my Workspace and its works.
Thanks!
Danilo de Lima
danilo_fme
  • Dec 14, 2015 5:12 PM UTC
Takashi
@takashi
i have this attribute: atts_names: safe,danilo, inovacao
And i would like to remove the word danilo from my attribute atts_names? Using python
Thanks
  • Dec 15, 2015 2:25 AM UTC
@takashi
Thanks
There may be various approaches. e.g.
# Use List
    src = feature.getAttribute('attr_names')
    if src:
        attrNames = []
        for attr in str(src).split(','):
            if attr.strip() != 'danilo':
                attrNames.append(attr)
        feature.setAttribute('attr_names', ','.join(attrNames))
# Use Regular Expression
import re
    if src:
        repl = lambda m: ',' if m.group(1) and m.group(2) else ''
        feature.setAttribute('attr_names', re.sub(r'(,?)\s*danilo\s*(,?)', repl, str(src)))
Regarding Python language, please learn with web sites or books.
BTW, why not use the StringReplacer?
  • Attributes: attr_names
  • Text to Match: (,\s*danilo\s*|\s*danilo\s*,|\s*danilo\s*)
  • Replacement Text: <blank>
  • Use Regular Expressions: yes
"No Coding Required" (in most cases) is an advantage of FME ;)
danilo_fme
  • Dec 15, 2015 12:15 PM UTC
Thanks again @takashi :)
  • May 12, 2016 2:52 PM UTC
Takashi
@tasashi
This method doesn't seem to work for me. I am trying to get all the attribute names from my input MapInfo files from a generic "schema" reader.
I am using FME2013 and I have also tried with the followings and nothing seemed to have worked.
feature.getListAttribute ('attribute{}.name') - this gives me a generic out put of ['zmap_max_x', 'zmap_max_y', 'zmap_min_x', 'zmap_min_y', 'zmap_null_value']
feature.getAttribute ('attribute{}.name')
I'm new to python and hopefully this description makes sense. Thanks!
  • May 12, 2016 4:06 PM UTC
@tasashi
Hi @judychang, FME Objects Python API has been upgrated in 2012, and the "getListAttribute" is a method in the old API. I don't remember the exact behavior of PythonCaller in FME 2013, but perhaps it still can work with the old API. See also this article: New Python FME Objects API in FME 2012
  • May 16, 2016 3:28 AM UTC
Thanks. My getListAttribute works if I use import pyfme but not if I use import fmeobjects..
  • May 24, 2016 4:47 PM UTC
@tasashi
