Get text from 1 element out of an XML attribute.
  • Mar 19, 2018 8:56 AM UTC
  • 62 views
Quick question: I have a attribute containing a larger xml file. I need the text of one element as a new attribute. It's two levels deep. I tried messing around with the flattner but I can't get it to work.
Within the root, it looks like this:
<BG:gelijk StUF:entiteittype="NPS">
<BG:inp.bsn>*VALUE I NEED*</BG:inp.bsn>
</BG:gelijk>
Can someone help me out? Thanks!
  • Mar 19, 2018 9:06 AM UTC
Hi @mvdorst, the XMLFlattener should work to extract the value of the <inp.bsn> element with these parameters.
  • Elements to Match: inp.bsn
  • Attributes to Expose: inp.bsn
However, it requires a premise that the XML namespaces (BG, StUF) are declared properly in the source XML document.
  • Mar 19, 2018 9:28 AM UTC
I forget the expose part, thanks! What if I would want expose whatever is in
with the name of inside element as attribute name, and the text as value. Is this possible? If not no problem, there are only a finite ammount of options, but it would save me manually check for each.
  • Mar 19, 2018 9:42 AM UTC
Exposing attribute name is optional, and it's necessary only if you need to refer to the attribute in the subsequent transformers or writer feature types when creating the workspace.
Would you like to use "NPS" as the name of attribute that stores "*VALUE I NEED*"?
If so, a possible way is to use the XMLXQueryExtractor.
