Get coordinates from tiled geometry?
  • Dec 13, 2018 12:23 PM UTC
  • 6 replies
  • 96 views
alanaliberti
Hi FMErs
Is there a way to extract the bottom-left coordinates from an output geometry using the Tiler transformer?
The reason is that I'm tiling/filing a geometry (to CAD format) and would like to use the bottom-left coordinates as file names, like for example "x=12000 - y=3000.dwg".
Please let me know if you need me to elaborate or if it is not clear.
Many thanks
  • Dec 13, 2018 12:25 PM UTC
Have you looked at the BoundsExtractor?
alanaliberti
  • Dec 13, 2018 12:36 PM UTC
Thanks for super fast answer
It's not quite what I need to achieve I think, because I needed the full coordinates of the tile, regardless if it has geometry in it or not.
Like, if I'm tiling at 5000,5000 but my minimum x for geometry in this particular tile is 5123, I even though wanted my tile filename to be named "5000,5000"
Perhaps I should change my approach?
  • Dec 13, 2018 12:39 PM UTC
Personally I like to use the _column and _row attributes from the Tiler to fanout my tiles. But you could also use them to calculate the tile coordinates if you know the seed coordinates used by the Tiler.
alanaliberti
  • Dec 13, 2018 12:53 PM UTC
Might be an idea, but in my case, even though I'm starting my seed at 0,0, the way it works it starts the tiling counting from the first geometry it finds in x,y, which in case are variable
jdh
Forum|alt.badge.img+41
  • Dec 13, 2018 3:44 PM UTC
You should be able to determine the theoretical bounds of your tile by using the the boundsExtractor as @david_r suggests and using an expression like
(floor(minX/tile_interval_x)*tile_interval_x)+seedX
For your data that would be
@Evaluate(@floor(@Value(_xmin)/5000)*5000)
@Evaluate(@floor(@Value(_ymin)/5000)*5000)
alanaliberti
  • Dec 13, 2018 5:36 PM UTC
That's pretty smart. Many thanks @david_r and @jdh :)
