Georeference Revit file and read in FME
  • April 2, 2020
  • 85 views
gianpiero
Hii,
I have a .rvt file that I have georeferenced in Revit (epsj 23032 - UTMED50 32N). Now, my target is to visualize that file in FME. I'll show you how I tried to do it:
In the first figure I show you about the Revit survey point, and for me it's ok. Because the coordinates values are coerent with the coordinate system of the project.
In the second figure I show you about FME reader setting that I have used.
When I use the reader to import the file in FME Desktop 2020 the model don't match with the correct location :-(
Someone can help me!!!
Regards
Gianpiero
Best answer by virtualcitymatt
Does this article help at all?
https://knowledge.safe.com/articles/596/revit-geolocation-tutorial.html
virtualcitymatt
Forum|alt.badge.img+47
gianpiero
  • April 2, 2020
Thanks for your suggestion, after I read this article I found in reader parameters the solution!
virtualcitymatt
Great, thanks for letting me know!
