Georeference rasters listed in a geodatabase field?
  • Nov 24, 2023 11:32 PM UTC
  • 100 views
lacy
Here is my scenario: I need to very roughly georeference thousands of scanned air photos that are tracked in a file geodatabase. Oversimplifying things considerably, my fields look like:
Filename (which contains location of the raster tif on disk)
Center_X (map coordinate)
Center_Y
Rotation (always zero for my simple exercise)
ground_resolution (in map coordinate units)
I want to feed each "filename" to the rastergeoreferencer, using Center_X, Center_Y, rotation, and ground resolution. But I'm conceptually stuck... rastergeoreferencer obviously wants input from a raster reader, not a text string with the path to the raster. See the rub?
Can somebody give me a push in the right direction?
Thanks!!
Best answer by takashi
Hi @lacy​ ,
You can use FeatureReader to read any format raster features whose file paths are read from the geodatabase dataset, then perform georeferencing on the read rasters.
Geodatabase Reader -> FeatureReader -> RasterGeoreferencer
Note that you will have to set "Merge Initiator and Result" to the Accumulation Mode paremtert to propagate attributes from geodatabase to the raster features.
  • Nov 25, 2023 3:54 AM UTC
Hi @lacy​ ,
lacy
  • Nov 27, 2023 2:44 PM UTC
Hi @lacy​ ,
Thank you! This is exactly the push in the right direction I needed. I tested, and FeatureReader works exactly as I hoped.
