Georeference multiple CAD file
  • Sep 5, 2018 12:28 PM UTC
  • 113 views
Good morning,
I am trying to georeference a few CAD files by using FME. I have a script that can be used in AutoCAD to achieve this (), but I would rather have everything completed within FME. It is working for some but not all, I'm not sure what I am missing. Any assistance would be great!
Thank you!
David Prosack
I figured out why not all are referencing correctly. Within CAD I had to change the View from SHEET to WORLD. Is there a way to do that in FME?
gio
Forum|alt.badge.img+15
  • Sep 5, 2018 4:02 PM UTC
the transformations are in the txt file.
Just parse it and use the attributes to set up relevant transformers in fme.
There is a scale, move, rotate and another scaler.
Thanks @gio
I was able to georeference the CAD file. The original problem was that not all CAD files were referencing in correctly. However after some investigating, I figured out that this was being caused by the view in AutoCAD being set to something other than WORLD. I am wondering if there is a way to set CAD files to WORLD in FME, instead of SHEET, as it was set to that before hand.
Thanks,
David
