GeometryValidator - self intersections in 2D
  • May 25, 2016
  • 8 replies
  • 100 views
I am trying to detect errors in a bunch of mapinfo polygon files. I am using GeometryValidator and its Self-Intersections in 2D to try to pick up the error below but it doesn't fail. Did I miss anything or do anything wrong?
Thanks!
incorrect polygon(top) vs. correct polygon(bottom):
attached files can be found via this link https://www.dropbox.com/sh/oim1ywj4t1ud24h/AABw-89...
Forum|alt.badge.img+5
  • May 25, 2016
Just to make sure I'm reading this correctly:
  • There's a checkmark in front of 'Self-Intersections in 2D'
  • The feature is coming out of the 'Passed' port, not 'Repaired'
I tried drawing something similar and validate it, it was repaired by the Validator.
this was in 2016.1.
  • May 25, 2016
this was in 2016.1.
Hi @kim,
Yes I have 'Self-Intersections in 2D' ticked and I have 'Attempt Repair' as 'No' and everything comes out in the 'PASSED' output. I am using FME 2013.
  • May 25, 2016
Could you perhaps upload a mapinfo or ffs file here with these two polygons so we can try to reproduce?
  • May 26, 2016
Sorry I couldn't upload the mapinfo files here - it wouldn't let me?
  • May 27, 2016
Maybe try Dropbox, Google Drive or Microsoft OneDrive. They will all let you share files over a URL.
  • May 30, 2016
Thanks! I've edited my question and post a link.
  • May 30, 2016
Hi
Thanks for the dataset. I tested the following
  • Self-intersections in 2D: No ? Passed
  • Self-intersections in 2D: Yes, Attempt repair: Yes ? Repaired
  • Self-intersections in 2D: Yes, Attempt repair: No ? Failed
This was using FME 2016.1 and the results were as I expected. It is possible that you've stumbled upon a bug in your version of FME that has since been corrected.
If you're using FME 2013 I would highly recommend considering an upgrade. If you're hesitant, you can always install FME 2016 next to FME 2013, this way you can choose whichever version to use for each task.
David
  • May 31, 2016
Hi
David
Thanks for the help David!
