GeometryValidator misses self-intersection error
  • August 18, 2016
  • 7 replies
  • 150 views
Greetings.
I have a self-intersecting polygon which is not being recognised as such by the GeometryValidator. The "Self-intersections in 2D" option in the transformer parameters is checked and most other self-intersecting geometries are detected. However, a small percentage are not. How come FME sees this as a valid geometry when my oracle database rejects it?
SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT
FME Desktop 2016.1.0.1 (20160516 - Build 16494 - WIN32)
I have attached the geometry as ESRI shapefile to this post. Any insight would be much appreciated.
Best answer by takashi
Hi @philipp_voelker, looks like the polygon touches with itself if you see it with Data Inspector, but there seems to be a very small gap actually. In my quick test, the Bufferer with amount of 1e-9 didn't create intersection, but with amount 1e-8 created intersection.
Left: Buffer Amount = 1e-9, Right: Buffer Amount = 1e-8
erik_jan
Forum|alt.badge.img+26
  • August 18, 2016
Does that geometry fail any other test too?
The GeometryValidator tests top down and will list all failures, but will show the first failure as the error.
  • August 19, 2016
No, it passes all tests.
Thanks for the answer, I will have a go at using the Bufferer once I'm back at work.
mark2atsafe
Forum|alt.badge.img+59
Yes, maybe Oracle tests to fewer decimal places than FME. Perhaps use a CoordinateRounder before the GeometryValidator to test that (and hopefully fix the issue)
  • August 21, 2016
The issue is that vertices for self-touching points are missing on the edge. The Chopper and Snapper (Segment Snapping) might work to insert vertices so that the GeometryValidator can detect self-intersection. Assuming that the "igds_eleme" is unique ID attribute:
Using the Bufferer was the right call. Thanks a lot, @takashi!
