GeometryExtractor WKT output splitting out multipolygons onto separate lines
joshuajames1979
Forum|alt.badge.img+7
Hi there. I am outputting SQL data into a CSV into well known text. Some of these features are polygons and others are multipolygons. I am finding in the output some multipolygon WKT strings are spilling over into other fields which throws everything out. I'm not sure the field length is exceeding the maximum length for a CSV but is there anything I can do to keep it all on one line or is this a problem with multipolygons?
I'm using a GeometryExtractor to convert to WTK, then a couple of StringReplacers to remove Z and change the SRID from 0 to 3857 so the csv can be brought into Power BI. Most are appearing fine.
Regards,
Josh
nielsgerrits
Forum|alt.badge.img+56
I would use a 2DForcer before the GeometryExtractor to remove Z, maybe the string replacement is corrupting the WKT?
joshuajames1979
Thanks for that. I saw your previous message about the delimiter. You might be right as it is splitting where the commas should be. I changed the delimiter to # however and when I open the CSV I still need to change text to columns for the first lot of columns with # but the WKT field is still split up by the commas.
joshuajames1979
All good. I imported into Excel using the # and it all works.
