I have a number of points in EPSG:4326 and a number of polygons / areas in EPSG:4326. I need to get the geometry of the polygon and the attributes from the points. They only relate spatially with many points within a polygon.
I've tried spatial relator, but it seems just to pass the points to next transformer and not the polygon geometry. Same with point on area overlayer.
Do I need another transformer, or have I just missed some handles in the named transformers?
