Geometry Challenge - Split polygon based on percentage 70/30
  • Jun 23, 2025 12:11 PM UTC
  • 6 replies
  • 240 views
galigis
Forum|alt.badge.img+22
Hi all,
I’m exploring a workaround to split a polygon based on a 70/30 area ratio:
  • 70% area → Type A
  • 30% area → Type B
Some visual explanation is included below.
The geometry of the split doesn’t need to follow a specific direction — any orientation is fine as long as the 70/30 ratio is maintained.
Has anyone come across a method or workaround to achieve this?
Thanks! 😊
itsmatt
Forum|alt.badge.img+48
  • Jun 24, 2025 7:28 AM UTC
The only thing that I can think of is an iterative approach.
E.g., Randomly pick a point inside the polygon, pick a random direction and then cut the polygon in two. compare areas and then progressively sweep the line through the polygon. At some point you should get pretty close.
I played around with creating just 100 random lines though just a box and even this approach got me within half a percent every time. upping to 1000 random lines I was getting withing 0.05% consistently. The approach is pretty brute force but relatively simple.  Depending on how accurate you need the areas this might be an ok approach
max_h
Forum|alt.badge.img+39
  • Jun 24, 2025 8:13 AM UTC
Would a ‘donut’ split be acceptable?
As in you use a scaler and scale the area by 70% and then clip it with the original one, so you got 70% inner area and 30% outer ring.
itsmatt
  • Jun 24, 2025 9:04 AM UTC
Oh this is a nice approach!
matthias_ct
Forum|alt.badge.img+5
  • Jun 24, 2025 11:16 AM UTC
For convex polygons, the following approach works:
For a given x-value, you draw a vertical cutting line. Since the polygon is convex, this line divides the polygon into exactly two parts. This creates a continuous and monotonically increasing function p_x, which represents the percentage of the total polygon area on the left side of the line.
You choose two values, x_min and x_max, for which the corresponding percentages p_min and p_max (automatically: p_min < p_max). Then you can perform a binary search to find the value of x where p_x equals 70%.
Forum|alt.badge.img+54
  • Jun 24, 2025 12:45 PM UTC
Does the split have to be a straight line?
hkingsbury
Forum|alt.badge.img+73
  • Jun 24, 2025 10:23 PM UTC
You could tile it, and then count the number of tiles and split based on that. SpatialSorter might be a useful transformer.
The more tiles, the more accurate the split/nicer the line. You could also smooth/generalise the line to make it a bit nicer
