Geometry Challenge - Create cutlines for map series following line
  • Jan 27, 2026 10:03 PM UTC
  • 101 views
galigis
Forum|alt.badge.img+22
Hi All,
I am working on an automation process to generate cutlines for use in a map series. These cutlines must have a consistent length and be positioned within the overlapping areas of the map sheets. In addition, the cutlines need to follow the orientation of the main alignment to support accurate mapping production.
Below is an example illustrating the challenge:
I have tried several workarounds, but I have not been able to get it to work.
Any ideas?
Best answer by geomancer
Not sure what you have tried already, so here is my attempt:
  1. Chop the line into features of 2 vertices (Chopper)
  2. Calculate the azimuth of each of these lines
  3. Get the overlaps of the polygons (AreaOnAreaOverlayer)
  4. For each overlap get the center point (CenterPointReplacer)
  5. For each center point find the nearest line (NeighborFinder, merge the attributes)
  6. From the results of the NeighborFinder you can create a line of your preferred length that is perpendicular to the line at that location
There is some nice math in the transformers AttributeManager_Line, VertexCreator_Start and VertexCreator_End 😉
The attached workspace was made with FME Form 2023.1.1.0
geomancer
Forum|alt.badge.img+71
  • Jan 28, 2026 12:42 PM UTC
galigis
  • Feb 2, 2026 4:46 PM UTC
Thanks ​@geomancer - your solution did the trick! :)
geomancer
  • Feb 2, 2026 4:51 PM UTC
Always glad to help!
