GeoJSON with LineString from JSON
  • Apr 10, 2019 9:32 AM UTC
  • 82 views
jugoslaviaa
Hi all,
I have a JSON file. Each object in the file has the coordinate of the start and end point of a line. I would like to transform it to geojson file with linestring.
Any ideas how can i do this?
Example:
        "cityName" : "Brussel",
        "endPoint.x" : "4.31888222694397",
        "endPoint.y" : 50.79171001911163,
        "startPoint.x" : "4.3186622858047485",
        "startPoint.y" : 50.79149007797241
Best
Best answer by redgeographics
The easiest option would be to use 2 VertexCreators, the first one to replace the current geometry (if there is any) with a point using startPoint.x and startPoint.y and then a second one to add a point using endPoint.x and endPoint.y
Forum|alt.badge.img+63
jugoslaviaa
  • Apr 10, 2019 12:13 PM UTC
Works! Thank you very much =)
