GeographicNeighborFinder - does not work after SQLExecutor
  • May 16, 2019 6:04 PM UTC
  • 98 views
robertr
Hello community,
I was using the GeographicNeighborFinder until now without a problem.
Today I wanted to automate the process even more and suddenly the GNF does not match anything even if (by running the old way), it does match a few hundred items.
The things I changed:
Instead of loading 2 excel files as readers -> I obtain the 2 excel files in FME:
-the first one by doing a join in between 2 excel files (like a VLookup - I was doing this manually until now);
-the second one via database query (I was manually updating an excel query until now);
Although with the Inspector I see the exact rows and columns I had (and would have) in the desired Excel file, the GNF does not seem to like it.
It would save me a lot of time if I could just do it as I have tried now.
Can anyone tell me where I got this one wrong?
erik_jan
Forum|alt.badge.img+26
  • May 16, 2019 6:32 PM UTC
I would start with connecting Inspector transformer to the Tester and Reprojector to check if the data going into the GeographicNeighborFinder are in fact within the tolerance of the GNF.
You can also use the caches to check the coordinates, but Inspector transformers allow to view them in the same window.
robertr
  • May 16, 2019 7:13 PM UTC
Good tip. I did add the Inspector and it seems both datasets forward the 2 lat/long columns that should give the GNF the data it needs to compute the search.
erik_jan
  • May 16, 2019 7:19 PM UTC
But do they both actually have the geometry? If one has the attributes and the other a geometry, The GNF will not find a match. In that case you will need to use the VertexCreator to build the geometry from the attributes.
robertr
  • May 16, 2019 7:24 PM UTC
Facepalm! Geez. That was it. How could I not see that?
It did work now.
Many thanks! @erik_jan
