Generating a bounding polygon from point data and surface interpolation
  • June 23, 2015
  • 163 views
I have point data representing yield measurements within a field (typically 30-40k pts).
I want to create a bounding polygon to represent the field boundary and interpolate selected variables as surface/contour maps (e.g.. bushels/ac).
The steps I have tried are:
1. Generate a bounding polygon -
- Reprojected lat/long to UTM
- Buffered points to 15m
- applied AreaOnArea overlay
- applied Dissolver
Apparently this is not the correct workflow since the processing takes forever.
2. Contour point attribute -
I'm looking through the Knowledge Center for examples of using ContourGenerator transformer to generate 2D surface maps from point data and can only find examples showing how to generate 3D terrain/DEM data.
What transformers should I be using?
  • June 24, 2015
The HullAccumulator might help you to create the bounding polygon.
To create a surface/contour, try using the SurfaceModeller after adding an attribute value to z coordinate for every point, with the 3DForcer.
Takashi
