Generate sequence attributes along lines
  • August 16, 2016
  • 6 replies
  • 120 views
danilo_fme
Forum|alt.badge.img+55
Hello Users,
My situation: I have connected lines with a attribute lengh each lines: _length.
I need to get this attribute _length and break in two anothers one: att_begin and att_end for each lines.
For example line 1: has the attribute _length = 39.7. I would like to take this and generate att_begin=0 and att_end = 39.7.
The line 2 has the attribute _length = 84. Is necessary to generate att_begin=39.8 ( in sequence number before ) and att_end=123.8 ( 39.8 + 84 ).
Attached my Source data.
Best answer by takashi
Hi @danilo_inovacao, if you are looking for a way to sort the line features based on their connecting order, the LineJoiner and PathSplitter might help you.
  • LineJoiner: Set 'Yes' to the 'Preserve Lines as Path Segments' parameter, and specify a list name to store attributes of the input features.
  • PathSplitter: Specify the list name to the 'List Attribute' parameter.
The lines will be output from the PathSplitter in their connecting order. I think you can then calculate desired values with the StatisticsCalculator (use Cumulative port) or the AttributeCreator (Enable Adjacent Feature Attributes option).
  • August 16, 2016
mark2atsafe
Forum|alt.badge.img+59
  • August 16, 2016
+1 for the use of the StatisticsCalculator cumulative port. I would never have thought of that!
danilo_fme
  • August 16, 2016
Hello @takahi and @Mark2AtSafe thanks yours answer.
I did put the these transformers on workspace and in the Transformer StatisticsCalculator the Attribute to Analyse is _length, correct?
Thanks
mark2atsafe
  • August 16, 2016
Thanks
I think so. Then the _sum value in the features output through the Cumulative port will return the accumulated distance up to that point. That will be the final length and (_sum - length) will be the start point.
ps - hope you're enjoying the Olympics! Pity the soccer semis went the wrong way and the final couldn't be Brazil vs Canada. But I suppose there are plenty of Germans and Swedes here who would disagree!
  • August 17, 2016
Thanks
Yes, but I intend to use only features from the Cumulative port. See also the attached example (FME 2016.1.1): cumulative-sum.fmwt
gio
Forum|alt.badge.img+15
  • August 17, 2016
if the lines are ordered (or can be ordered) you can also just take their lengths and use a attribute creator with lead or lag.
