generate points within a polygon
hello all,
i have a simple square polygon,
i am trying to place an array on evenly spaced points within it,
i have found RandomPointGenerator in the FME store, it does the trick, but i need to define the X and Y offset values,
any help would be great :)
cheers
gio
Forum|alt.badge.img+15
  • May 28, 2016
@fungry21
Create a grid within the square polygon using a 2DGridAccumulator on the input object (your square).
Use point type to create.
Counter to count number of your input objects and then using a attirubutecreator or expressionevaluator to calculate the squareroot of your input objects and round this value.
Use value to create x, and y (number of cells )
I assume by square you mean a even sided rectangle. (else you need to calculate aspect ratio first)
  • May 28, 2016
Not sure I understand exactly what you're trying to do...
But does this help? Use the PointCloudCombiner as described in this blog post
http://blog.safe.com/2016/05/point-cloud-power/
Look in the heading FME can make point clouds from any geometry
Or have a look at the 2DGridAccumulator and maybe need to Clipper it against the source geometry.
