generate numbers between two values
  • Jul 24, 2024 9:15 AM UTC
  • 218 views
zizou84
Hello,
I need to generate data by year (whereas I only have periods)
To do this, I'll need to generate numbers between two values (typically years) to make a join with my existing data.
I thought of using counter but I need input data, I just want to generate all the numbers between two values (for ex 1791 to 2024)
thanks in advance for your help
Best answer by nielsgerrits
I think you want a feature for each year between 1791 and 2024? One way to do this is:
  • Expected input is one feature with attributes FromYear = 1791 and ToYear = 2024.
  • Calculate the difference between the 2 years.
    • AttributeCreator
      • AttributeName: Years
      • AttributeValue: @Evaluate(@Value(ToYear)-@Value(FromYear))
  • Create a feature for each year.
    • Cloner
      • Number of Copies: Years
      • Copy Number: Year Number
  • Create a Year attribute for each feature
    • AttributeCreator
      • AttributeValue: @Evaluate(@Value(FromYear)+@Value(YearNumber))
nielsgerrits
Forum|alt.badge.img+67
  • Jul 24, 2024 9:28 AM UTC
    • AttributeCreator
    • Cloner
    • AttributeCreator
zizou84
  • Jul 24, 2024 9:50 AM UTC
Thank you very much, I will try your solution !
zizou84
  • Jul 24, 2024 11:49 AM UTC
Works perfectly !
Thanks a lot for the help!
