Generate complex lines with points
geo-x
Dear FME community.
I've to generate a complex line with a points listing. Complew why ? Because the line is a composite of lines and curves. The information of the geometric type is in point's attributes like that :
I only tried with the LineBuilder but I don't know how to do with the curves objects.
Thank you for your help.
Best answer by david_r
Sounds like you need a spline interpolator.
Maybe you can find some inspiration here: https://knowledge.safe.com/questions/2706/create-cubic-bezier-curves.html
  • August 28, 2018
You can use the LineBuilder to create the straight line segments and the 2DArcReplacer to create the arc segments.
Finally, assemble the arcs and the straights using the PathBuilder.
geo-x
  • August 28, 2018
Thank you @david_r but how can I use the transformer 2DArcReplacer in this case ? The arc must be snap to the points and I think this transformer generate random curves no ?
  • August 28, 2018
I don't think there's anything random about the curve that is generated, you can specify all the curve parameters in the 2DArcReplacer. If you need the curve starting point to snap to the input point geometry, you could use the Offsetter to move the resulting curve.
If you need a more specific answer, it would help if you could post a sample point with curve parameters here.
geo-x
  • August 28, 2018
Finally, what I need is ArcEstimator but for more than 3 points :-)
  • August 28, 2018
geo-x
  • August 28, 2018
Thank you very much @david_r. This link is exceptionnal because @takashi ask a question :-)
  • August 28, 2018
True!
