Generate complex lines with points
  • Aug 28, 2018 8:42 AM UTC
  • 7 replies
  • 129 views
geo-x
Dear FME community.
I've to generate a complex line with a points listing. Complew why ? Because the line is a composite of lines and curves. The information of the geometric type is in point's attributes like that :
I only tried with the LineBuilder but I don't know how to do with the curves objects.
Thank you for your help.
Best answer by david_r
Sounds like you need a spline interpolator.
Maybe you can find some inspiration here: https://knowledge.safe.com/questions/2706/create-cubic-bezier-curves.html
  • Aug 28, 2018 9:00 AM UTC
You can use the LineBuilder to create the straight line segments and the 2DArcReplacer to create the arc segments.
Finally, assemble the arcs and the straights using the PathBuilder.
geo-x
  • Aug 28, 2018 12:13 PM UTC
Thank you @david_r but how can I use the transformer 2DArcReplacer in this case ? The arc must be snap to the points and I think this transformer generate random curves no ?
  • Aug 28, 2018 12:20 PM UTC
I don't think there's anything random about the curve that is generated, you can specify all the curve parameters in the 2DArcReplacer. If you need the curve starting point to snap to the input point geometry, you could use the Offsetter to move the resulting curve.
If you need a more specific answer, it would help if you could post a sample point with curve parameters here.
geo-x
  • Aug 28, 2018 1:04 PM UTC
Finally, what I need is ArcEstimator but for more than 3 points :-)
  • Aug 28, 2018 1:10 PM UTC
geo-x
  • Aug 28, 2018 3:27 PM UTC
Thank you very much @david_r. This link is exceptionnal because @takashi ask a question :-)
  • Aug 28, 2018 3:59 PM UTC
True!
