generalizer creating 2d self intersections
  • Jun 7, 2018 1:40 PM UTC
  • 71 views
oliver.morris
Forum|alt.badge.img+14
Thanks for your help in advance, I am creating composite content, stacking polygons together from different 'surfaces' then clipping. This works as expected but it is almost exponentially creating additional vertices. This is an issue and as a result I need to generalize the output. Unfortunately when I use the generalizer tool the output geometry reports lots of invalid outputs, mainly 2d self intersections. Does anyone have any suggestions to help.
Many Thanks
Best answer by daveatsafe
Hi @olivermorris,
Changing the generalizer algorithm or settings may prevent the creation of the self-intersections.
The GeometryValidator transformer can be used to repair the self-intersections.
daveatsafe
Forum|alt.badge.img+24
  • Jun 7, 2018 4:36 PM UTC
Hi @olivermorris,
