GDB to GEOJSON
  • Jun 24, 2022 9:23 AM UTC
  • 363 views
viviancfhung
I'm try to translate a multilayer GDB file to GEOJSON file. As a result. I found all layers are merged into one single layer. How can I translate it into multilayer GEOJSON
rahulsharma
Forum|alt.badge.img+12
Hi @viviancfhung​
There are two options
I do not fully understand, File Geodatabase reader should read all the tables based on geometry.
Are you only seeing a single Feature Type?
Is it possible that you have selected "Single Merger Feature Type" in reader dialog?
If yes, please set this to "Individual Feature Type" on the reader dialog or Generate Workspace dialog.
Individual_FeatureTypeAnother option would be that you want to split the data based on some attribute into multiple files. For that, you will need to use Data Fanout. Please refer to the following article to get started.
FME Fanout
viviancfhung
  • Jun 28, 2022 1:25 AM UTC
Hi @viviancfhung​
FME Fanout
I will try, thanks
viviancfhung
  • Aug 12, 2022 7:46 AM UTC
Hi @viviancfhung​
FME Fanout
I try to use fanout, my FGDB dataset is
imageHow can I set in Fanout to convert the geojson by layer name
imageThis setting is failed
