Hi I have a GDB file with feature layers from ArcGIS Pro in it that I would like to use workbench to convert to CAD while maintaining the symbology colors.
I have extracted the colors of the symbology in hex code format *(E.g. #ffffff) into the attribute tables of the layers.
I added my GDB in as a Reader, added in an AttributeFilter, link the field that my symbology is dependent on back in ArcGIS, then added in a DWGStyler to every single possible option in that field in AttributeFilter.
I set the color of DWGStyler to be the field containing the hexcode, and then added in my output vis writer and connected everything.
But no matter what I try, the CAD file doesn't register any of that at all.
FME Color by attributeAs you can see, none of the hex colors seemed to have gotten into my CAD file.
You probably can find the answer in the translation log. I think you need to use a different value then a hex code to set the color. You can use the ColorConverterNew from the FME Hub to convert from HEX to FME color codes.
Hi @nielsgerrits​  thanks for replying! I'm still very new to FME (Literally started using this today).
I downloaded the ColorConverterNew and loaded it into my workbench as per the picture:
Updated workflow below:image.pngAll my hex codes should be in the correct format needed by ColorConverterNew:
Hex codesAnd after running the workspace there doesn't appear to be any warning. But opening the exported DWG file, it seems like nothing carried over in terms of colors?
CAD no colors
CAD no colors
In the ColorConverterNew, choose the from = HEX, to = FME.
In the DWGStyler, choose FME_COLOR, not HEX_COLOR.
Be aware, this will set the color of the line, not the color of the layer.
CAD no colors
ok so FME itself doesn't support working with Hex colors (at least I don't think so). Typically everything needs to be converted to fme color (0-1) or RGB (0-255).
In the ColorConverterNew you can pick FME as output color and then in the DWGStyler you can pick FME_COLOR from the list.
The AUTOCAD output here can be used, however, not in conjunction with the DWGStyler. The DWGStyler assumes that data are in fme's internal format rather than already prepared for ACAD
CAD no colors
Hi @virtualcitymatt​ & @nielsgerrits​ !
I think it worked, at least for polygonal layers. I will need to play around with points and polyline files.
ArcGIS Pro to CAD maintaining symbology
Do any of you know how I might be able to make a python script to automate the process? I have multiple files, all of which have the same data in their attribute tables where the color data exists to be passed into ColorConverterNew -> DWGStyler -> Writer.
Other solution​ without python.
Make a table (e.g. Excel) with colums e.g.
feature_layer,​ fill_color, line_color, ...
Merge the table with your data (FeatureMerger) and control the DwgStyler ​ with attributes.
It's for the moment more to work,​ but very easy to update the workflow in case of new featureclasses.
CAD no colors
How I do this:
  • Creator to initiate
  • FeatureReader (Directory and File Pathnames) to scan folder for files.
  • Filter only files needed using Tester / TestFilter / AttributeFilter.
  • Use FilenamePartExtractor to get _dirpath and _rootname.
  • FeatureReader to read dwg based on path_windows. Merge attributes.
  • Conversion, all group by path_windows etc to keep these attributes.
  • FeatureWriter to write results, using _dirpath and _rootname.
CAD no colors
By the way @nielsgerrits​ any chance you know how to convert points from a GDB to blocks in DWG?
I have no issues with polylines and polygons but I can't seem to get points to work.
Point To Block failI'm currently using AttributeCreator with the following settings
New Attribute | Attribute Value
autocad_entity| autocad_insert
autocad_block_name|BasicPoint
BasicPoint is the name of the point I created and saved in my BasicPoint.dwg file I'm using as a template.
No matter what I try the end results still is an empty cad file.
CAD no colors
There are 2 ways of creating blocks in dwg's:
  • Send an collection / Aggregate to a dwg (Feature)Writer
  • Send a point to a dwg (Feature)Writer, using the DWGStyler. This requires you to define a template file in the (Feature)Writer which contains the blocks referred to in the DWGStyler. I point to the same file when doing this.
CAD no colors
2nd method worked!Original PointsColor carried over but not on the block itselfBut the color data doesn't seem to be going through to the block itself:
image.pngIt shows up on the properties like in the screenshot of CAD but the points all seem to take color data from the layer?
CAD no colors
I'm also trying to follow along with your steps for batch conversion but I don't understand what I'm suppose to select and if I have selected any wrong info.imageimage.pngI'm linking this folder to the workspace and I think I can do a filter from the reader via Path Filter but I'm at a lost on what to do next.
CAD no colors
Use the feature with the path to the gdb (path_windows) as input for the FeatureReader, where field Dataset = attribute path_windows.
CAD no colors
CAD no colors
Yes exactly. Then under Output Ports, choose Single Output Port.
As the input is dynamic (based on attribute) the FeatureReader can not know what FeatureClasses it will get, that is the other screen you get. So you read everything, generic. Then you can use an AttributeExposer to expose fme_feature_type (in gdb, this is feature class name) split the features by featureclass, if needed.
CAD no colors
imageOk I added an AttributeExposer and then connected it to my ColorConverterNew but I don't see any of the fields I need that I would with a single file, did I miss a step somewhere?
CAD no colors
You you will need to expose these attributes as well. In the AttributeExposer, you can import from feature cache.
CAD no colors
imageI tried both import by Feature Cache and Dataset, both only seem to contain data at the folder level containing my gdbs, nothing specific from my gdb were there :/
CAD no colors
Ah, I see the issue.
First reader need to read the directory.
Second reader needs to read the gdb. So it should be a GDB reader, not a Directory reader.
CAD no colors
Nice I was able to retrieve the fields I need for color conversion! Now I'm stuck on how I'm suppose to export the files?
Also is there a way to handle errors? I'm assuming that a user might have both line and polygonal layers in their GDBs, and the line will still have a FillColorField, but all of the values should be null, so I think that might return a Rejected output.
Also I'm not sure what exactly is getting rejected in my FeatureReader reading GDB files o.O
Update, I have garbage data that is completely incompatible with my workspace which brings up a good point, is there a way I can handle bad files in a batch? Like just skip over them and let the user know which of those files were skipped?image.png
CAD no colors
Glad you got to the next step :) You probably want to start a new topic for a new question.
CAD no colors
imageOoph sorry but I haven't figured out what I need to put to export my files yet 😂
When I was running the single file process previously what I did was just type in a name of a dwg file.
For the batch processed version will this still apply?
If it does then I assume what happens is everything gets chucked into a single DWG file and not their own DWG file on a per GDB basis(Which is what I'm trying to achieve)?
CAD no colors
You can fanout on an attribute name. The DirectoryReader also has a filename and a rootname attribute. You can configure the FeatureReader to merge the attributes from the initiating feature, to merge the original filename to each feature and use that when writing.
