FuzzyStringCompareFrom2Datasets with +distance
  • May 3, 2018 9:36 AM UTC
  • 50 views
Hi all
is it possibe to insert a buffer distance inside the FuzzyStringCompareFrom2Datasets
I mean My goal is to compare the name of dataset a with name of dataset b within a distance of 500m
fmelizard
Forum|alt.badge.img+22
  • May 4, 2018 9:39 PM UTC
Hi @frsisani You can edit the FuzzyStringCompareFrom2Datasets by inserting a Bufferer (and make your own custom transformer) but you also might want to find those features over a certain ratio and then compare those spatially with a NeighborFinder. So you could do a spatial query and fuzzyCompareString in either order, or if you modify the custom transformer then you could use the Bufferer to help calculate the ratio.
