Format String with leading zeros
  • Apr 11, 2022 11:03 PM UTC
  • 1328 views
hanidraidi
How can I format a string with leading zeros (eg. seven zeros) through the "Format" string function in text editor?
For example, in attribute creator, I want to create a new attribute which takes input id field (e.g. its value 5), and I want to return 00000005.
The screenshot below better elaborates my case.
image.pngAny help is highly appreciated.
Hani,
Best answer by nielsgerrits
I think you want to pad a string? This can be done using
@(PadLeft,<string>,<padlenght>,<padchar>)
your example
@PadLeft(@Value(AttributeA),8,0)
As an alternative you can use the StringPadder.
danilo_fme
Forum|alt.badge.img+58
  • Apr 11, 2022 11:41 PM UTC
Hi @Hani Draidi​
I suggest you to use the transformer StringConcatenator:
String
Thanks in Advance,
Danilo
hanidraidi
  • Apr 11, 2022 11:59 PM UTC
Hi @Hani Draidi​
String
Thanks in Advance,
Danilo
Thanks for the valuable input Danilo,
This works perfectly with 1-digit number, but I need a solution that formats the string based on number of zeros (Maybe this is not elaborated in my question). For example if the number is 13, the result should be 6 zeros: 00000013
nielsgerrits
Forum|alt.badge.img+67
  • Apr 12, 2022 4:53 AM UTC
your example
hanidraidi
  • Apr 12, 2022 6:47 AM UTC
your example
Many Thanks @nielsgerrits​. It exactly does what I need!
Appreciated!
