Force FME to Run Command Prompt as Admin with FME Server
  • Jun 28, 2019 6:45 PM UTC
  • 90 views
Hi there,
I have a workspace that is using the SystemCaller to run an encryption/decryption process (GnuPG ). It runs fine from Desktop and Server when I set the FME Server Engines to use my Admin account, but when I set the Server Engines to use a service account (and I'm logged into that account), FME Desktop runs fine but Server fails to execute. I think I've narrowed it down to the fact that I need to force the Command Prompt to run as Admin from FME, but I'm not sure of how to do that. Any ideas?
Thanks!
Sam
stalknecht
Forum|alt.badge.img+22
  • Jun 30, 2019 10:07 PM UTC
User Account Control (UAC) will not let you execute the command without a prompt. The only way I can think of is dissabling UAC but that is a no go if you ask me.
But I don't think it is your issue what you describe because the systemcaller in FME desktop would then also be failing. Is it a network resource you are accessing from the server?
